Odrive 6401 Will not run on Mac OS High Sierra 10.13.5
Recently my odrive desktop sync agent stopped running in Mac OS High Sierra. I uninstalled and reinstalled desktop sync, but still can’t get it to run. I click to open the app but nothing happens.
mine is 10.13.5 and 6401 and all is perfect
Hi @yfhudak,
Try these steps and see if it helps:
This will reset the bin folder and re-run odrive. Hopefully this will clear out the issue. If it doesn’t can you try running this command next?
This will spit out some information to the console, can you copy and paste that here?
Awesome the first command worked for me! Thank You!
Great! Thanks @prestonjohnlewis. I’ll reference this in your other post, too.
Worked for me. Thanks very much!
