Is it ok to manually unsync a file while using odrive as a free account?
Hi @ulisses.b,
Unsync is a premium feature, so you won’t be able to unsync manually or automatically in the free version once the trial expires.
I’m saying using something like you proposed some time ago:
Is it allowed?
Hi @ulisses.b,
Yes, you can use method 2 - 4 in the free version.
Hi @ulisses.b, unsyncying is a feature of premium account but you can customize the setting only when you are in the trail period. So with odrive free account you can change the sync setting.
Which is the method? I cannot see the link anymore
Hi @daniele.dentamaro,
I have updated the post above to the new information.
