Sub folder automatic sync and intercloud transfers
I have 2 questions:
  1. Is it possible to have a specific directory/folder in a cloud storage to automatically download all contents without having to download other folders or files? If yes how can I do that?
  2. Can I transfer unsynced files from one cloud drive to another? Say I have a 2 GB backup file on my dropbox and I wish to move the file to one drive. Do i have to sync it locally then move the file and then unsync it on the destination? OR can I simply copy the unsynced file from source to destination? If I copy the unsynced file from source cloud to destination cloud, will I still be able to use the file by syncing it when needed?
Hi @subhashishkar,
  1. You can do this with folder sync rules:
    https://docs.odrive.com/docs/sync-source-changes#section-configure-folder-sync-rules
  2. Cloud to cloud data migration/copy is not supported right now. It would require using your system as an intermediary (download to local then copy/move to the other storage).
    Copying from Cloud to Cloud
