I have been using Odrive for sometime with several google and dropbox accounts. A couple a days ago odrive stop running (it could be more time as I was not paying attention).
I have a Macbook pro running OS X El Capitan.
The icon in the top bar disappear, when I relaunch the applications noting happens. I uninstall and reinstall and it’s the same. And, of course, the synchronization of files doesn’t work.
Hi @claracpvale,
Can you perform the following steps, please?
Run each the following commands separately in the terminal session (copy & paste + Enter) and then paste the output here:
Command 1:
`"/Applications/odrive.app/Contents/MacOS/odrive" -v`Command 2 (if Command 1 does not open odrive):
Command 1 Output:
Last login: Sat Jan 7 09:41:36 on console
claras-MBP:~ cainha$ “/Applications/odrive.app/Contents/MacOS/odrive” -v
Starting launcher with verbose output…
No product argument was passed in. Attempting to find product.conf…
Using path /Applications/odrive.app/Contents/Resources/product.conf…
Using /Users/cainha/.odrive as the installed folder path…
Attempting to mark the installed folder path as hidden…
Writing the product.conf file at /Users/cainha/.odrive…
Reading the version number from the version file…
Attempting to read systemAlertRoom from config…
Setting up diagnostics for buildNo: 6149, productName: prod, systemAlertRoom: 1358891
Creating launcher object…
Checking if another odrive process is running again to reduce the chances of a race condition…
Launching…
Got OSError exception [Errno 2] No such file or directory
File “”, line 177, in main
File “/Users/admin/hudson/workspace/Odrive_Mac_Master_Launcher/output/artifacts/build/odrive/MacOdrive/out00-PYZ.pyz/src.odrive_app.Launcher”, line 167, in launch
File “/Users/admin/hudson/workspace/Odrive_Mac_Master_Launcher/output/artifacts/build/odrive/MacOdrive/out00-PYZ.pyz/src.odrive_app.Launcher”, line 98, in _launch_app
File “/Users/admin/hudson/workspace/Odrive_Mac_Master_Launcher/output/artifacts/build/odrive/MacOdrive/out00-PYZ.pyz/subprocess”, line 711, in init
File “/Users/admin/hudson/workspace/Odrive_Mac_Master_Launcher/output/artifacts/build/odrive/MacOdrive/out00-PYZ.pyz/subprocess”, line 1343, in _execute_child
OSError: [Errno 2] No such file or directory
Could not launch, which means the app is already running
Command 2 output:
Last login: Sat Jan 7 11:29:10 on ttys000
claras-MBP:~ cainha$ bindir=$(ls -d “$HOME/.odrive/bin/”*/ | tail -1); echo $bindir;"${bindir}odriveapp.app/Contents/MacOS/odrive"
/Users/cainha/.odrive/bin/6110/
After running the 2 commands the icon appeared in the top bar and is synchronizing.
Thank you very much
Update: After closing terminal window the odrive stop working again.
Opening terminal window and running again the 2nd command you gave me, made the odrive start working … so, a more permanente solution will be needed ![]()
Hi @claracpvale,
It looks like the bin folder may be missing or have a problem. Try running this command from a terminal session:
This will reset the bin folder and re-run odrive. Hopefully this will clear out the issue.
A post was split to a new topic: Odrive crash on OS X 10.11.6
