Hi, this is the output of the command I get:
> Last login: Wed Jan 11 16:42:27 on ttys001
> Jonatans-iMac:~ armisoft$ bindir=$(ls -d "$HOME/.odrive/bin/"*/ | tail -1); echo $bindir;"${bindir}odriveapp.app/Contents/MacOS/odrive"
> /Users/armisoft/.odrive/bin/6149/
> 2017-01-11 16:49:17.574 odrive[21699:8159567] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x5f03, name = 'com.oxygen.odriveapp.ui.odrive.uiServer'
> See /usr/include/servers/bootstrap_defs.h for the error codes.
> Exception in thread Thread-1:
> Traceback (most recent call last):
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 801, in __bootstrap_inner
> File "/Users/admin/git/juggernaut/deploy/sandbox/lib/python2.7/site-packages/mixpanel_async/async_buffered_consumer.py", line 36, in run
> File "/Users/admin/git/juggernaut/deploy/sandbox/lib/python2.7/site-packages/mixpanel_async/async_buffered_consumer.py", line 255, in _sync_flush
> File "/Users/admin/git/juggernaut/deploy/sandbox/lib/python2.7/site-packages/mixpanel/__init__.py", line 433, in _flush_endpoint
> File "/Users/admin/git/juggernaut/deploy/sandbox/lib/python2.7/site-packages/mixpanel/__init__.py", line 335, in send
> File "/Users/admin/git/juggernaut/deploy/sandbox/lib/python2.7/site-packages/mixpanel/__init__.py", line 350, in _write_request
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 154, in urlopen
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 429, in open
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 447, in _open
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 407, in _call_chain
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1241, in https_open
> File "/usr/local/Cellar/python/2.7.12/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1198, in do_open
> URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)>
> 2017-01-11 16:49:19.475 odrive[21699:8159675] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0xd503, name = 'com.oxygen.odriveapp.uiServer'
> Segmentation fault: 11
And this is the latest crash report I have:
Process: odrive [21699]
Path: /Users/USER/*/odriveapp.app/Contents/MacOS/odrive
Identifier: com.oxygen.odriveapp
Version: 1.0 (1)
Code Type: X86-64 (Native)
Parent Process: bash [21688]
Responsible: Terminal [21686]
User ID: 501
Date/Time: 2017-01-11 16:49:19.502 +0100
OS Version: Mac OS X 10.11.6 (15G1108)
Report Version: 11
Anonymous UUID: F9765691-AE08-8DED-6407-463DBF579425
Time Awake Since Boot: 1200000 seconds
System Integrity Protection: enabled
Crashed Thread: 15
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
VM Regions Near 0x8:
__TEXT 000000010c67c000-000000010c6b5000 [ 228K] r-x/rwx SM=COW /Users/USER/*/odriveapp.app/Contents/MacOS/odrive
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff996bdf72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff996bd3b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff9229a124 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff922995ec __CFRunLoopRun + 1356
4 com.apple.CoreFoundation 0x00007fff92298e38 CFRunLoopRunSpecific + 296
5 com.apple.HIToolbox 0x00007fff8df81935 RunCurrentEventLoopInMode + 235
6 com.apple.HIToolbox 0x00007fff8df8176f ReceiveNextEventCommon + 432
7 com.apple.HIToolbox 0x00007fff8df815af _BlockUntilNextEventMatchingListInModeWithFilter + 71
8 com.apple.AppKit 0x00007fff8c93ddf6 _DPSNextEvent + 1067
9 com.apple.AppKit 0x00007fff8c93d226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
10 com.apple.AppKit 0x00007fff8c931d80 -[NSApplication run] + 682
11 com.apple.AppKit 0x00007fff8c8fb368 NSApplicationMain + 1176
12 com.oxygen.odriveapp 0x000000010c67ea1e main + 1314
13 com.oxygen.odriveapp 0x000000010c67d5c8 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff996c45e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff91578578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff91576341 start_wqthread + 13
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff996c4efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff8830d165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff8830cdcd _dispatch_mgr_thread + 52
Thread 3:: Dispatch queue: pythonOdriveApp
0 libsystem_kernel.dylib 0x00007fff996c407a __select + 10
1 time.so 0x0000000110164ac1 time_sleep + 136
2 Utility.so 0x000000010fe40b88 __Pyx_PyObject_Call + 101
3 Utility.so 0x000000010fe4df91 __pyx_pw_23Odrive_Mac_Master_Build_3src_7utility_7Utility_7Utility_66wait_for_stop_status + 399
4 MacOSUIService.so 0x00000001171b4c1d __Pyx_PyObject_CallMethO + 84
5 MacOSUIService.so 0x00000001171b5f9a __pyx_pw_23Odrive_Mac_Master_Build_3src_10odrive_app_8services_14MacOSUIService_14MacOSUIService_7run + 163
6 OdriveDesktopApp.so 0x000000010fa56f3a __Pyx_PyObject_CallMethO + 84
7 OdriveDesktopApp.so 0x000000010fa1caba __pyx_pw_23Odrive_Mac_Master_Build_3src_10odrive_app_16OdriveDesktopApp_16OdriveDesktopApp_7run + 2887
8 org.python.python 0x000000010c7098a0 PyObject_Call + 99
9 org.python.python 0x000000010c7899b8 PyEval_EvalFrameEx + 26425
10 org.python.python 0x000000010c78d721 fast_function + 264
11 org.python.python 0x000000010c789a84 PyEval_EvalFrameEx + 26629
12 org.python.python 0x000000010c78d721 fast_function + 264
13 org.python.python 0x000000010c789a84 PyEval_EvalFrameEx + 26629
14 org.python.python 0x000000010c78308d PyEval_EvalCodeEx + 1583
15 org.python.python 0x000000010c782a58 PyEval_EvalCode + 54
16 org.python.python 0x000000010c7a61ad run_mod + 53
17 org.python.python 0x000000010c7a636a PyRun_StringFlags + 109
18 org.python.python 0x000000010c7a62be PyRun_SimpleStringFlags + 69
19 com.oxygen.odriveapp 0x000000010c67ec0c __main_block_invoke + 422
20 libdispatch.dylib 0x00007fff8831293d _dispatch_call_block_and_release + 12
21 libdispatch.dylib 0x00007fff8830740b _dispatch_client_callout + 8
22 libdispatch.dylib 0x00007fff88319bd7 _dispatch_async_redirect_invoke + 1733
23 libdispatch.dylib 0x00007fff8830740b _dispatch_client_callout + 8
24 libdispatch.dylib 0x00007fff8830b29b _dispatch_root_queue_drain + 1890
25 libdispatch.dylib 0x00007fff8830ab00 _dispatch_worker_thread3 + 91
26 libsystem_pthread.dylib 0x00007fff915784de _pthread_wqthread + 1129
27 libsystem_pthread.dylib 0x00007fff91576341 start_wqthread + 13
Thread 4:
Thread 5:: Dispatch queue: statusItemRefreshQueue
5 com.apple.Foundation 0x00007fff8c5b1ed9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6 com.apple.Foundation 0x00007fff8c5b1db8 -[NSRunLoop(NSRunLoop) run] + 74
7 com.oxygen.odriveapp 0x000000010c6847e6 __33-[AppDelegate setupTrayRefresher]_block_invoke + 243
8 libdispatch.dylib 0x00007fff8831293d _dispatch_call_block_and_release + 12
9 libdispatch.dylib 0x00007fff8830740b _dispatch_client_callout + 8
10 libdispatch.dylib 0x00007fff8830c03b _dispatch_queue_drain + 754
11 libdispatch.dylib 0x00007fff88312707 _dispatch_queue_invoke + 549
12 libdispatch.dylib 0x00007fff8830740b _dispatch_client_callout + 8
13 libdispatch.dylib 0x00007fff8830b29b _dispatch_root_queue_drain + 1890
14 libdispatch.dylib 0x00007fff8830ab00 _dispatch_worker_thread3 + 91
15 libsystem_pthread.dylib 0x00007fff915784de _pthread_wqthread + 1129
16 libsystem_pthread.dylib 0x00007fff91576341 start_wqthread + 13
Thread 6:
Thread 7:
Thread 8:: Dispatch queue: com.apple.root.utility-qos.overcommit
0 libdispatch.dylib 0x00007fff88312c0d _dispatch_semaphore_wait_slow + 59
1 com.apple.CoreFoundation 0x00007fff922fb2ee ____CFMachPortDeallocate_block_invoke + 30
2 libdispatch.dylib 0x00007fff8831293d _dispatch_call_block_and_release + 12
Thread 9:
Thread 10:
Thread 11:: Dispatch queue: animateTrayQueue
7 com.oxygen.odriveapp 0x000000010c69263d __26-[AppDelegate animateTray]_block_invoke + 292
Thread 12:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff8ca93d95 _NSEventThread + 149
6 libsystem_pthread.dylib 0x00007fff9157899d _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff9157891a _pthread_start + 168
8 libsystem_pthread.dylib 0x00007fff91576351 thread_start + 13
Thread 13:
Thread 14:
Thread 15 Crashed:
0 com.apple.CoreFoundation 0x00007fff922b7729 CFMessagePortIsValid + 9
1 com.apple.CoreFoundation 0x00007fff922b7612 CFMessagePortCreateRunLoopSource + 34
2 _ctypes.so 0x000000011052cfdf ffi_call_unix64 + 79
3 _ctypes.so 0x000000011052d814 ffi_call + 836
4 _ctypes.so 0x0000000110528e2f _ctypes_callproc + 591
5 _ctypes.so 0x0000000110523483 PyCFuncPtr_call + 1049
6 ThreadedCFMessagePortServer.so 0x00000001170d9dd0 __Pyx_PyObject_Call + 101
7 ThreadedCFMessagePortServer.so 0x00000001170dd330 __pyx_pw_23Odrive_Mac_Master_Build_3src_10odrive_app_7servers_27ThreadedCFMessagePortServer_27ThreadedCFMessagePortServer_7_create_run_loop_source + 3021
8 ThreadedCFMessagePortServer.so 0x00000001170d9e84 __Pyx_PyObject_CallMethO + 84
9 ThreadedCFMessagePortServer.so 0x00000001170dac5c __pyx_pw_23Odrive_Mac_Master_Build_3src_10odrive_app_7servers_27ThreadedCFMessagePortServer_27ThreadedCFMessagePortServer_3start + 803
10 EventDispatcher.so 0x0000000116a781f1 __Pyx_PyObject_CallMethO + 84
11 EventDispatcher.so 0x0000000116a81977 __pyx_pf_23Odrive_Mac_Master_Build_3src_10odrive_app_11dispatchers_15EventDispatcher_15EventDispatcher_18dispatch_subsequent_launch + 1013
12 org.python.python 0x000000010c7098a0 PyObject_Call + 99
13 org.python.python 0x000000010c78a227 PyEval_EvalFrameEx + 28584
14 org.python.python 0x000000010c78d721 fast_function + 264
15 org.python.python 0x000000010c789a84 PyEval_EvalFrameEx + 26629
16 org.python.python 0x000000010c78d721 fast_function + 264
17 org.python.python 0x000000010c789a84 PyEval_EvalFrameEx + 26629
18 org.python.python 0x000000010c78308d PyEval_EvalCodeEx + 1583
19 org.python.python 0x000000010c727d31 function_call + 352
20 org.python.python 0x000000010c7098a0 PyObject_Call + 99
21 org.python.python 0x000000010c7146a6 instancemethod_call + 173
22 org.python.python 0x000000010c7098a0 PyObject_Call + 99
23 org.python.python 0x000000010c78d063 PyEval_CallObjectWithKeywords + 165
24 org.python.python 0x000000010c7b99a6 t_bootstrap + 70
25 libsystem_pthread.dylib 0x00007fff9157899d _pthread_body + 131
26 libsystem_pthread.dylib 0x00007fff9157891a _pthread_start + 168
27 libsystem_pthread.dylib 0x00007fff91576351 thread_start + 13
Thread 16:
Thread 17:
Thread 15 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0xf2001370b234dfc6 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x0000700000ebcfc0 rsp: 0x0000700000ebcfb0
r8: 0x00000001105366f0 r9: 0x0000000110535970 r10: 0x0000700000ebcfa0 r11: 0x00007fff922b75f0
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000700000ebd150 r15: 0x0000000000000000
rip: 0x00007fff922b7729 rfl: 0x0000000000010202 cr2: 0x0000000000000008
Logical CPU: 6
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x10c67c000 - 0x10c6b4fff +com.oxygen.odriveapp (1.0 - 1) <C9082A2C-2AAB-3F18-9061-212099ED8583> /Users/USER/*/odriveapp.app/Contents/MacOS/odrive
0x10c6ff000 - 0x10c814ff7 +org.python.python (2.7.12, [c] 2001-2016 Python Software Foundation. - 2.7.12) <257C71D7-7270-35F7-B294-2C9CFFBF3248> /Users/USER/*/odriveapp.app/Contents/Frameworks/Python.framework/Versions/2.7/Python
0x10f9ea000 -
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 3027385
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=266.4M resident=0K(0%) swapped_out_or_unallocated=266.4M(100%)
Writable regions: Total=198.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=198.0M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 8K 2
CG image 4148K 13
CG shared images 208K 7
CoreAnimation 40K 5
CoreUI image file 192K 4
Dispatch continuations 16.0M 2
IOKit 12K 3
Image IO 36.0M 5
Kernel Alloc Once 8K 3
MALLOC 88.3M 26
MALLOC guard page 32K 7
Memory Tag 242 12K 2
OpenCL 8K 2
STACK GUARD 56.1M 19
Stack 19.7M 19
VM_ALLOCATE 18.6M 68
__DATA 22.7M 582
__IMAGE 528K 2
__LINKEDIT 108.9M 281
__TEXT 157.5M 480
__UNICODE 552K 2
mapped file 44.6M 21
shared memory 16.3M 11
TOTAL 592.5M 1546
Thank in advance,
Jonatan.
