Odrive menubar icon not clickable + odrive not working
Success! Thanks for the quick fix.
Great! Thanks for confirming @kimberlykeyton.
Here is one more (hopefully last) test build.
This is a tricky issue. We can’t reproduce it in-house, so we’ve refactored some likely areas and hope that it will hit the issues noted so far.
Update
This fix has been officially released in our latest version. My thanks to everyone for their help in tracking it down! :
Just to be clear, I click on this Link then download and install? Will I lose a folder structure or well files have to be re synchro or settings re done?
Hi @sheldon.maye,
Yes you just download and install. It will upgrade your current installation and keep everything the way it was.
Thanks for this update, Mac prod6694. I’ve been having this unclickable problem for a while. Found the uninstall/reinstall instructions and that fixed it for a while, but it always came back. I just installed 6694 and it is working great.
6694 seems to have done the trick!
