default 21:32:55.600923 +0900 opendirectoryd Client: , UID: 0, EUID: 0, GID: 0, EGID: 0
default 21:32:55.601050 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.049930 +0900 opendirectoryd completed, delivered 2 results
default 21:32:59.055582 +0900 opendirectoryd Client: , UID: 0, EUID: 0, GID: 0, EGID: 0
default 21:32:59.055683 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.066109 +0900 opendirectoryd Client: , UID: 0, EUID: 0, GID: 0, EGID: 0
default 21:32:59.066373 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.069574 +0900 opendirectoryd Client: , UID: 0, EUID: 0, GID: 0, EGID: 0
default 21:32:59.069690 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.070017 +0900 opendirectoryd Client: , UID: 0, EUID: 0, GID: 20, EGID: 20
default 21:32:59.070207 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.070792 +0900 opendirectoryd Client: , UID: 501, EUID: 501, GID: 20, EGID: 20
default 21:32:59.070893 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.090034 +0900 CommCenter #I CSIAppInfo.ApplicationActivationObserver: handleLSNotitifcation_sync: Application exited:
default 21:32:59.091194 +0900 gamed GKClientProxy: clientForBundleID:
default 21:32:59.091243 +0900 gamed GKClientProxy: updateIfRecentlyInstalled
default 21:32:59.091310 +0900 gamed GKDataTransport: initWithBag:
default 21:32:59.091368 +0900 gamed GKMultiplayerMatchService: cancelGameInviteWithHandler:
default 21:32:59.091427 +0900 gamed GKDataTransport: initWithBag:
default 21:32:59.091479 +0900 gamed GKMutltiplayerMatchService: cancelOutstandingMatchRequestWithHandler
default 21:32:59.091548 +0900 gamed GKDataRequestManager+Nearby: clearAllNearbyInvites
default 21:32:59.091597 +0900 gamed GKBulletinController sharedController
default 21:32:59.091672 +0900 gamed GKBulletinController+Common getBulletinsOfType:
default 21:32:59.092278 +0900 CommCenter #I CSIAppInfo.ApplicationActivationObserver: handleLSNotitifcation_sync: Application exited:
default 21:32:59.122975 +0900 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 21:32:59.126023 +0900 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 21:32:59.126275 +0900 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 21:32:59.126590 +0900 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 21:32:59.127035 +0900 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 21:32:59.140411 +0900 opendirectoryd Client: , UID: 501, EUID: 501, GID: 20, EGID: 20
default 21:32:59.140525 +0900 opendirectoryd completed, delivered 1 result
default 21:32:59.147938 +0900 Finder subsystem: com.apple.siri, category: Intents, enable_level: 1, persist_level: 1, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 0, enable_private_data: 0
default 21:32:59.153458 +0900 Finder subsystem: com.apple.clouddocs, category: default, enable_level: 0, persist_level: 0, default_ttl: 14, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 0, enable_private_data: 0
default 21:32:59.156576 +0900 Finder got a connection for: com.apple.cache_delete
default 21:32:59.157479 +0900 Finder got proxy: for service: com.apple.cache_delete
