I'm Not Seeing Odrive Sign on Synced Folders and Files Anymore
Hello @Odrive,
Before, I used to see a kind of small circular red around folders and files which had been synced, which differentiates them from folders and files which are yet synced. However, I am not seeing anything like that anymore. I was wondering if that is how it is now or something is wrong on my side!
Hi @awoobforknowledge,
  • The odrive folders that are still placeholders (unsynced) will have a pinkish colored tab/border.
  • Files that are synced locally will have greenish colored checkmarks.
  • Folders that have files synced locally inside them and do not have any files that need to be uploaded, or files that are actively uploading, will show a greenish colored checkmark.
Are you seeing any of the above?
Thanks @Tony.
I am only the pinkish colored tab/border for folders that are placeholders and Odrive’s logo sign for placeholders/unsynced files.
However, I am not seeing the greenish colored checkmarks for files and folders you described above in your second and third points.
Thanks.
Do you still have the right-click context menu that allows for sync, unsync, share link, etc.?
Is this on Mac or Windows?
Yes, I still have it.
It is on Windows.
There are a couple of things we can look at/try.
  • Try performing a installation repair with the desktop installer.
  • This could be a result of overcrowding in the Windows registry for icon overlays. Take a look at this post for more information on that: Icon overlays not showing up in Windows
It is possible that the odrive icons are being superseded by another set of icons.
Thanks a lot @Tony,
The installation repair with the desktop installer solved the problem.
Even though I think I don’t need the post link you gave above anymore, however, I want to make it known that it says I don’t have access to the topic.
Thanks so much.
Great! Thanks for the follow-up @awoobforknowledge.
I also corrected the link above. Thanks for letting me know.
