How can I pause uploads?
Isnt there a pause button of some sorts? Can’t seem to find it…
You can stop sync under the very first entry in the odrive tray menu. It will say either “Syncing changes” or “Ready to sync new changes”. Under that entry you will find “Stop automatic sync”. Selecting that will stop automatic sync until you start it again.
thanks so much. I’m still in the process of exploring the tool… I might ask again something in the future… best regards!
No problem! If you have any other question that hasn’t been covered before, just create another topic and we’ll get to it asap.
ah yes, is there a way to see the upload speed or estimated time until everything is finished?
Take a look at this post:
