Hi Jim,
Did you happen to send another diag when this was happening? I would like to take a look.
Hi Jim,
I hadnât, but just did on startup â it is doing its thing (I again shut down Evernote).
Jim
Heh⌠yeah this time it was massive Firefox cache activity. We really just need to exclude ~/Library/Caches from monitoring. I will see what can be done about this.
Hello,
I have the same behavior.
There is a fix to the problem?
Hi!
I have the same issue - always have - are there any workarounds?
Justin
Hi @jhoff33,
Generally elevated CPU is either active syncing, the background scanning process that happens on odrive start-up and periodically afterwards, or excessive file system events from the OS. For scanning, the larger your local odrive structure, the more work odrive needs to do to keep it all in sync.
If you send a diagnostic from the odrive menu I can take a deeper look.
Hi @Tony,
Thank you for the response! I have just submitted a report. Iâm not sure how I can identify it for you - you can find it by my account name? Please let me know what I can do to assist! Indeed this only happens when I first startup odrive. The cpu goes crazy for about 15-20 minutes each time. If this is expected behavior I suppose thereâs nothing to be done but I would be interested in your thoughts.
Thank you again!
Justin
Hi @jhoff33,
I donât see anything that raises a red flag in the diagnostic. There is some routine scanning, but your folder structure isnât very large and the scanning isnât lasting all that long. There is a fair amount of filesystem activity, and that could be increasing CPU.
The next time you see this happen can you note the time it starts and stops (if possible) and send another diagnostic?
How often would you say this comes up?
Hi @Tony,
Thanks again for the prompt response. I have just submitted another Diagnostic.
For your questions:
I do tend to reboot my computer frequently for various reasons, so unfortunately this problem hits me a lot.
I love the software, and I am grateful to have been grandfathered in so I get the unsync feature for free, itâs a wonderful feature!
Thanks again for any assistance or advice you can provide!
Hi @jhoff33,
I took a look and odrive was doing its extensive initial scanning on startup. There is always a flurry of activity on startup as odrive checks every nook and cranny to make sure everything is as it should be. Generally I donât expect it to be as long as you are seeing here unless the structure is extensive, but there can be other factors at play that can lengthen the time and impact.
In any case, it isnât anything I would call âabnormalâ. We run hot on startup, unfortunately. There was a post by another user regarding setting the priority of the odrive process. Itâs not ideal, but it could help if you find that odrive slows other things down on startup: Decrease CPU priority so ODrive doesnât interfere with other processes
Sadly I have this problem too. odrive churns and churns using 53.6 Watts on battery 95.8 degrees F fan blowing. Itâs a bummer, I really wanted to love this. Maybe you can tighten the indexing system someday. Dropbox has it down, but they have a big budgetâŚ
p.s. This is on a MacBook Pro (Retina, 15-inch, Late 2013) running 10.12.4 (16E195) and odrive version prod 6296.
Hi @matthew.james.briggs,
The next major release we are working on will optimize this a lot, especially for large datasets.
Thatâs good news! Whatâs the timeline? Does the mac application auto-update? Thanks.
This post is the best answer I have for information on the next major release:
It is likely that we will not auto-update the current release to the new one - at least for quite some time - because so much will have changed. Once it is available it will be announced via all of our channels.
