Getting into that in the guest account requires turning off file vault and decrypting my files. That’s just too much trouble to go through at this time. I will just stop using odrive for now.
Sorry we couldn’t get this working for you. I can’t tell why this is happening. All of the steps we are taking indicate that the extension is installed properly…
Just let me know when/if you are up for working through it a bit more.
I had this problem in a Win10 machine, and now in OSX 10.11 . What is going on? I want my context menu back, please!
(i have tried the above terminal commands, to no avail. Terminal tells me the extension is installed, but it does not appear in the System Preferences Extensions panel.)
This one has me stumped. I guess one more thing we can look at is the console to see if there are any messages regarding a failure to load extensions. When you take a look, does anything stand out?
