Hello - I understand that OSX 10.15 Catalina isn’t supported yet so take this as a FYI.
I’m getting (over time) many FinderSyncExtension processes (from odrive) which end up taking up half my 18 core CPU. I saw the post regarding Samba, this is not on a samba server. If I try to reboot the machine while there are FinderSyncExtension processes it hangs.
I didn’t have this issue before upgrading to 10.15. Any quick tips would be handy and I’m happy to do any testing.
Hi @joe1,
Thanks for posting. We are currently trying to get out a new desktop release and then we’ll start looking at 10.15.
If you toggle the odrive extension off in System Preferences -> Extensions and “Relaunch” Finder by holding down the option key and right-clicking on the Finder icon in the Dock, do the processes remain or are they exited after a few seconds?
It is normal to see multiple instances of the odrive Finder Extension since MacOS will launch new instances for apps that use a Finder instance and it can also happen when opening multiple Finder windows. What are the apps you are using the most on your system and do any of them offer a Finder window for browsing/saving files?
