is there anyway to enable LAN-aware syncing similar to Dropbox. I am syncing to a NAS that is on the same network (1000 Mb/s) some of the time so a direct sync that doesn’t go through odrive’s servers would be much speedier. this is mostly an issue for the initial sync but could be convenient when I create large datasets in the future.
All connections between sources and odrive are direct. If you are on your LAN, odrive syncs directly over your LAN to your NAS. We don’t need to route connections through the cloud.
Make sure that when you link the NAS, you are linking against the local IP address (unless you have some form of split DNS enabled). You can actually link it twice if you want to have it available locally and remotely. Once against the local IP and once against the external IP. Of course, you will only be able to use the local IP link on your local LAN.
When I do this I have to give the link a different name which then creates a new link on my computer… I got the impression from your message that I could make both links sync the same data?
