Can't Get Window To Go Away Please Help
I’ve tried rebooting and I can’t get this odrive window to go away.
Here is a desktop video of what I am talking about.
What can I do?
Hi @Chris.Hall,
This is strange. Has this always happened on your system, or is it a recent development?
Can you send a diagnostic from the odrive tray menu? (How do I send a diagnostic?)
It just started recently.
current_odrive_status.txt (32.4 KB)
Thanks @Chris.Hall. I’m looking into this.
Does this same thing happen with the normal dialogs, like send diagnostics, or do those behave normally.
Everything else is normal.
Hi @Chris.Hall,
When you get a chance, can you try this version and see if it exhibits the same behavior?
We aren’t able to reproduce the issue, but modified a couple of things that may address this.
That seems to have fixed it!
Thank you!
