All of the sudden, the blue circle with the check box started showing up on all of my desktop icons. I’m only using the odrive sync to Amazon. Its the same check box that I see when a file successfully syncs.
I just restarted sync (windows 5049) and the blue file badge just changed to a dual user icon for all my desktop items. What’s that mean? I’m pretty sure its related to the latest update for odrive. Feeling a little uncomfortable with the product…
Generally I’ve seen that an F5 “refresh” will correct the issue. If that doesn’t work, it is possible a icon cache reset can fix the issue, although not guaranteed. You would need to open a command prompt and copy and paste the following in, hitting enter afterward: ie4uinit.exe -ClearIconCache && taskkill /IM explorer.exe /F && del "%localappdata%\IconCache.db" /A && del "%localappdata%\Microsoft\Windows\Explorer\iconcache*" /A && timeout /T 1 && explorer.exe
