Trouble with odrive on mac
Hello
i’m on MacOs Mojave 10.14.5
and when i’m trying to launch odrive, nothing happens !
odrive worked before, i’m using it for 3 years …
i tried to reinstall it, but nothing happens better
could somebody help me ?
Hi @romain.col,
Can you try these steps and see if it helps:
This will reset the bin folder and re-run odrive.
the message that appears
“No matching processes belonging to you were found”
Hi @romain.col,
That is normal if odrive is not running. The first command tries to kill any running odrive processes. Is anything else shown after that?
it works !
thank you so much
Great! Thanks for confirming @romain.col!
