I have win 10, I am fully updated on Odrive, I restarted my computer, I reinstalled Odrive, nothing.
Everything works except the Trash bin
I click the odrive icon at the bottom and click on Trash bin because there are files to remove, but the menu button will no longer show the Empty/Restore options.
I have tried everything, but I can’t click it. No error code, just wont happen.
Hi @glampasona,
That is strange. I wonder if it has something to do with the resolution or screen orientation.
Do you have multiple monitors?
What happens if you move your task bar to another side of your screen (like the left side)?
Does changing the screen resolution affect anything?
