TransportSecurity~RFxxxxxx.TMP
Hello @Odrive,
Please, what is this TransportSecurity~RFxxxxxx.TMP folder I am seeing before my Amazon Cloud Drive folder file/folder path when searching for a file or folder on my system ?
Thanks.
Hi @awoobforknowledge ,
This folder is not related to odrive. A quick search shows that “TransportSecurity” tmp folders are associated with the Chromium framework (web browsers like Google Chrome, opera, Edge, etc…).
Can you provide a screenshot of what you are seeing?
Thanks a lot @Tony , for the wonderful support.
Your clarifications made me thought of restarting the application I was using to search for files and folders. After restarting the application, the “TransportSecurity~RFxxxxxxxx.TMP” is no more showing in the file/folder path after search.
Thanks.
