Torrent to odrive
I’m using odrive for syncing research data files from my university to Amazon Drive. They are distributed over bittorrent. Would it cause problems on A) odrive and B) Amazon if I download the torrent to a location in my odrive folder? That means as the pieces are downloaded from the torrent, they would be synced to Amazon, causing lots of small operations.
I don’t think it will cause a problem, but it will be pretty inefficient and it may leave a bunch of stuff in the odrive trash.
It may be best to either download them elsewhere and move them into odrive after complete, or to stop sync on odrive until the files are ready to be synced to Amazon. You can stop sync under the top menu item in the odrive tray menu.
