Syncing Folder Across Two Computers?
Hello,
I have files on my computer at home that are syncing to Amazon Cloud, and I want those files to sync/download automatically from Amazon Cloud down to a folder on my work computer.
How do I accomplish that? I’m having a little trouble understanding how to make a mirror like that work.
Josh
As long as you have odrive installed on your work computer you can sync any folder from your Amazon Drive to that computer.
There are two ways you can do this:
  1. Access it from the default odrive folder that is created after you install: https://docs.odrive.com/docs/sync-your-odrive
  2. Use the “sync to odrive” feature to set another folder to sync with the remote location. In your case, the folder on your work computer may start out as an empty folder. Once you setup the “sync to odrive” relationship with the location in Amazon Drive you can then sync down the content into that local folder: https://docs.odrive.com/docs/manage-sync#section-sync-external-folders
