Syncing between cloud storage accounts
I’m wondering if it’s possible to use odrive to Sync multiple Cloud accounts. As an example, if someone went into my One Drive file and saved it to the One Drive cloud I would want it to update a file (these are both Excel) I have in my box account. This would need to be done when I have my computer off. Is this possible?
Hello,
While not possible to split a single file between multiple folders or clouds you can share a folder where the file is saved from dropbox
This article outlines the process: https://www.odrive.com/features/spaces
