Sync preferences, per folder
Continuing the discussion from New desktop and web releases today! (04-01-2016):
Sorry but I don’t fully understand the “sync preferences, per folder”. Can you explain?
Patrick
When you choose “save and apply to new files and folders” on that that dialog for a chosen folder, the options you set will be “saved” and used for that folder. For example, if you chose “Everything” with “include subfolders”, all new files added to that folder structure will be synced locally. This also means that any new folders that are added remotely will be automatically expanded and all files inside synced locally.
