Hi there - we are a team of 3 all using dropbox and odrive. We are having issues where the files are not syncing across different accounts - can someone help here? All using Mac OS El Capitan.
Hi @ben,
Can you provide some additional information (with some examples) on the discrepancies you are seeing?
Are you all using the same odrive account? If not, are you all using the same Dropbox account?
Hi there - we are all using different drop box accounts but using a same shared team folder. We all use different dropbox accounts too. It’s been a bit off - not syncing for the past couple of days - however I’ve come in this monring and it all looks synced. So problem solved for the minute - but I’ll reply to this post if it happens again.
Okay. Thanks for the update!
