Sync Company SharePoint
Hi!
At the moment I’m using OneDrive for Business to synchronize SharePoint content from the company (internal/external access is possible). I’m testing odrive at the moment because OneDrive is very often not working as expected.
Is it possible with odrive to synchronize different SharePoint libraries?
BR
Manuel
Hi @schwarz.manuel09,
Unfortunately the integration does not support Sharepoint libraries, at the moment. I know it is something we’d like to add, but it is not not currently prioritized.
thank you for the information.
BR
Manuel
Sharepoint is now supported!
