Hi there. I notice that the “Include Subfolders” option is hit and miss with OneDrive. Also, more importantly, if I create a folder on Sharepoint its not syncing locally through oDrive. Any ideas?
Hi @mrmikemayo ,
For Sharepoint, are you able to see this folder from the odrive web client? (https://www.odrive.com/account/myodrive)
If so, but you still aren’t seeing it on the desktop client we can take a look at the logs and see what might be happening. Likewise for the OneDrive bulk download issue.
For OneDrive the likely reason is that odrive is encountering enough errors to abort the bulk download, but we can also take a look at this in the logs if you have a recent example.
The “sync activity log” is located here:
Once open (as main.log), please save it to your Desktop and then send it to me via a direct message. I will message you so you just have to reply to that private post.
Please also send a diagnostic from the odrive tray menu:
