I created my first Shared Space which has worked really well except…
I put a bunch of files in, sync’d them, all good
I renamed the files. Again all good - the new names showed on everyone’s computers
I created some new folders and dragged the files into them to reorganise them. PROBLEM!
My computer is fine; when I view the share using “Open Web Preview”) it shows all the files. What have I done wrong?
Not all the files on my desktop (Windows 7, odrive 5184) show the odrive status overlay (the ones which don’t are the files which are showing up twice), but all say they are sync’d.
Hi Peter,
Thanks for the details. I am not able to reproduce what you are seeing. Can you submit a diagnostic? It would be very beneficial if you can create this again and then send it over.
Hi @peter1,
I took a look and I think you may be seeing something that has since been corrected as part of some move tracking enhancements in the latest version of odrive. Can you grab it and try this scenario again?
Hi Tony, thanks - isn’t odrive meant to keep itself up-to-date? I’ve been looking in the System Tray icon for a ‘check for updates’ or ‘Update now’ feature, but seen nothing… I’ve downloaded the new installer from the link you provided.
We generally release to the download page first, then push to autoupdater a day or two after that. You can stay up to date on our releases and what they contain in the Announcements section:
