I setup an SFTP Account on my Synology NAS. I have been able to connect via MacOS SFTP command from the terminal using my user name and password. I setup a local SFTP account on odrive, but cannot connect - every time I try I get ‘SFTP Server Error’ on a popup. Is there a log file somewhere so I can troubleshoot?
Hi @jello4,
The diagnostic is showing an error with the kex algorithm available on the server. Are you able to see how sshd is setup on the synology? It looks like odrive is not able to find a compatible setting.
Ok, I shotgunned it an enabled everything. I am now getting this:
Which makes me thing I am moving down the line. my start path is \home
which does exist in the directory that my Mac SFTP program logs in to. I also tried \ with no avail…
