Selectively ignore folders in odrive
I was wondering if there was a way to ignore certain folders in odrive, because there’s a cache folder of apps that I have backed up that I could care less about and don’t want to worry about deleting every time I see it.
I don’t know if unsyncing the folder is enough, since new files are added and the folder might be recreated.
Is this a folder that you’ve created, or is it created by an application?
If its a folder you’ve created and you just don’t want to sync it to the cloud, you can add a “~” character to the beginning of the folder to have it ignored.
Thank you. Unfortunately, it’s created by the application that backs up folders, so I guess it’ll just create a new one.
