Can you tell me the best-practice way to rename a folder on any given cloud storage? It seems that if I rename a folder on one computer in Odrive, another computer running Odrive re-uploads the old folder name and gets a new foldername.cloudf.
For example:
Amazon Cloud Drive/test exists and displays on two computers running odrive
On computer 1, I rename test to test1
On computer 2, I get a new file named test1.cloudf and computer 2 starts uploading all of the test folder to Amazon Cloud Drive
Sorry for taking so long to reply, was finally able to gain access to the remote computer again.
tl;dr: Once the initial sync completed, this issue no longer presents itself.
I did some testing, and it looks like it was an issue because this computer was still completing it’s first sync. After that finished (which I sped up by removing some folders from the sync), this issue no longer presented itself.
I will say that the initial sync from this computer was almost 2 TB of files to Amazon Cloud Drive and Google Drive, so that may be a longer initial sync than you’ve been able to play around a lot with.
