Renaming folders Odrive
Can I rename my folder once the project is setup in Procore. What if I want the folder name to change.
Hi @joey.freeman,
You cannot change any project folder names or any of the folders names above the projects (like the company name) from odrive. If you want to change the project name, it would need to be done from the Procore web client.
Keep in mind that if the folder name changes, you will also need to remove the old “sync to odrive” folder and set it up again against the new name. odrive will then scan through and determine the sync state of everything inside.
