Put.io as a storage provider?
Hi! Right now it’s possible to add put.io via the WebDAV interface (odrive can’t seem to connect to them via FTP), but I was wondering if you would consider adding them as a proper provider? I talked to Hasan from put.io via email, and he said that they would be happy to help you add them as a provider.
