Procore Project Folder Name
We are new to Odrive and testing it to see how it works with Procore before installing across all our users. One immediate issue that has come up is that the folder names for each project is using the Project PO number as a prefix and then the project name. Can this be changed to only show the project name?
Hi @jacob1,
There isn’t currently a way to adjust the naming scheme of the project folders, but I will speak to the product team about this request.
To be clear, you do not want the project number to be part of the listing, at all?
Correct. PO numbering formats can vary widely depending on the client. Having that be the prefix causes the sorting to be all out of wack for us and makes it hard to find the project in windows explorer.
