Still uploads 2 to 4 files.
Hi @r6han768,
I split this off to a new thread to dig into it more.
Can you send a diagnostic from the odrive tray menu so I can take a closer look. This will also create a file named “current_odrive_status.txt”, can you attach that here, as well?
Can you also post the contents of your “odrive_user_premium_conf.txt” file?
Just to double-check, you restarted odrive after making the config file change?
When I have uploads stall out I have found rebooting normally solves the issue.
We actually have a new version coming out soon that will improve the ability to restrict uploads. Stay tuned.
Hi @Zareaus,
The version I mentioned above is available now:
