Possible to sync two folders from Mac to same destination?
Hi there,
I’ve been using Odrive for ages, but up until now have been using just one Odrive folder on my computer to sync a bunch of sub-folders to Amazon Drive. I’ve looked through the documentation and can’t find anything on this, is it possible for me to also add an external drive to sync to the Amazon Drive? I.e. One source on my computer and the external drive, or do they all the files have to be in the Odrive folder?
If not possible under the free plan, is it possible under the premium plan?
Thanks in advance!
Hi @seanpaune,
This is supported with our Premium “sync to odrive” feature. This feature allows you to sync any local folder to any remote storage.
Here is the general documentation for the feature
Here is the specific information for external drives
In your scenario, you should be able to right-click on a folder in your external drive and select “sync to odrive”. Then you will select the remote folder to sync with. The folder names on the local and remote side need to match, so just keep that in mind. If a remote folder with that name doesn’t exist in the location you choose, a new one will be created.
Got it. Had a feeling it was a premium feature. Looks like it’s time I finally pay up!
Thank you for the help!
Sure thing @seanpaune! Just let us know if you need anything.
