(Windows 10, odrive version “prod 6484”.) I have restarted my machine with no change. I don’t seem to have any other network issues. The files are in a google drive account if that makes a difference.
I saw some older threads that mention this error, but non seemed to completely apply or have a solution.
Edit:
When trying to go to “Manage Storage” I get “Unable to manage storage.
Please check your network connection”
Hi @Zareaus,
Did this issue just start happening recently?
Can you send a diagnostic from the odrive menu? It may fail if there are networking issues, but you can attach the “current_odrive_status.txt” file that is also generated in the root of the odrive folder.
Hi @Zareaus,
It looks like a DNS issue. For some reason www.odrive.com is resolving to the wrong IP on your network and hitting ibosscloud.com. Could this be linked to the third party firewall?
Hi @Zareaus,
I am not familiar with iboss, but it might be filtering based on application type (client/agent identification), call patterns, or something else.
odrive shouldn’t be caching any ips for very long, but you could try restarting odrive to see if it makes a difference. Otherwise I think you will need to speak to the IT team about it.
