Actually, here’s another question. Are you planning on eventually working in a LAN sync feature with odrive (similar to the LAN sync ability dropbox has)? So, basically, if you had multiple odrive clients on a local LAN and you were trying to sync a cloud stored file down to a client, it would preferentially sync from another client on the LAN if one existed that already had the file synched.
