I’m about to reinstall my windows drive. My odrive folder is on a separate HDD.
If I simply reinstall odrive and login, will it pick up the sync where it left off, or will it try to DL everything from the cloud overwriting local files?
Is there a settings folder anywhere I can backup and subsequently restore?
