Title. So, google drive and Onedrive for business is in the same folder, google drive syncs fine. But, even though the correct .cloudf file is there for onedrive, it doesnt recognize it, or want to sync. What to do?
Tia
Hi @ljblignaut,
Can you send a diagnostic from the odrive tray menu so that I can take a closer look at the configuration?
Do you see anything listed in the “not allowed” section of the odrive tray menu?
Are you able to browse the OD4B link from the web client?
