Under account Maxim I create a folder -Indo and share it with Nkap.
Both computer (Maxim and Npak) are tun under Windows 10 Pro, with all latert patch.
Both before use microsoft One dirve to sync changes.
On both computer Onedrive are not started and autosync in desabled.
When at computer Npak i create file I recieve error : The file is locked on microsft one drive and no sync from Nkap is possible.
This happened with any new file or folder I create on Nkap hard drive at onedrive shared folder.
From Maxim all sync goes well.
Hi @maximts,
Unfortunately it is not possible, currently, to add/edit files inside a OneDrive shared folder, even if you have the proper perms. This is something we plan to improve in the future.
You can use odrive Spaces, instead, to accomplish the same thing. Have you tried Spaces yet? You can find out more about them here: https://www.odrive.com/features/spaces
