Currently, I am syncing files to Procore projects that will eventually end, and when I close out the project, inactivating it from Procore, will the files still be on my computer, or will they automatically get removed?
Since I currently have the free version, will I have to “manually” unsync all the folders, then resync them to remove this project?
Hi @kmattson,
When you mark a Procore project as inactive, it will no longer be returned in the projects listing coming from Procore. This will look like the project has been deleted from Procore storage, so odrive will sync that change by deleting the corresponding project folder(sending it to your OS Trash/Recycle Bin) on your local system.
