Hi there! I’m having some issues using odrive with MacOs.
When I want to save a file, “recent places” doesn’t work within odrive folder. I have to follow the path from the main folder every time. I think it started a couple of months ago.
Is there anyone else suffering the same thing?
Hi Tony!
It always goes back to a folder, but while I was recording my screen I realized that somehow is related to the color tags from Finder.
It only worked with a file located in a folder with no tags.
For now, I will remove the tags but I would like to know how to fix it.
I think this problem is not with odrive.
But I thought it was because I was checking out of odrive and it didn’t happen but I think it was related to the tags.
