Thanks @joe1!
The stat calls are definitely unexpectedly long. On my system they are less than 1ms. Do you have any network drives mounted on that system?
In any case, seeing this gives me an idea that may help the situation. Stay tuned…
Thanks @joe1!
No network drives, I do have a bunch of external drives connected though so I disconnected them to see if it made a difference but the activity didn’t change. I ran a profile on system calls and indeed the stats are taking a long time, but only with the FinderSyncExtension processes.
There’s a burst of stats coming from FindSyncExtension about once every second.
Thanks for the ongoing support.
Hey @joe1,
Give this build a shot. It reduces the background stat calls being made so it should hopefully provide some decent results
https://www.odrive.com/s/0085dbc3-5fc1-473d-aba7-0910fc0d592f-5d8c40b4
That one looks good! Awesome, thanks heaps for that, it’s good to have the sync/unsync finder menus back
Thanks again.
Great! Thanks for all of the helpful info Joe!
Edit:
The latest versions of the odrive desktop client now have this fix, as well.
