Odrive creates random data files when synced with S3 storage
Hello,
I set up a link to Amazon S3 on odrive. When I sync a folder from my Dropbox and I select the path folder on odrive, it correctly syncs that folder to odrive. I can view this through https://www.odrive.com/browse.
On S3 however, the folder and subfolders are not synced correctly. They are being uploaded as a list of gibberish data-string folders with data-string images such as folder names:
241fe91f-3b27-419f-8db8-98bf6a61d3f7
68ce3cd4-895e-4178-afbf-4a464f473526
I don’t know what to do - I tried everything and followed the steps exactly as stated on the forum and guides so link s3 to odrive. PS. I just upgraded this morning to premium, not sure if that makes a difference.
Hi @Ryousef,
Did you choose the S3 Enhanced integration type vs the simple delimited? Please take a look at this thread for more information about this these two options and which one is right for your use case:
Yes - that worked now - Thank you! I had misunderstood that section when I first read it. I thought we should NOT choose the delimited option if we have an existing bucket. Thank you for clarifying and for your prompt response!
Great! Thanks for confirming.
