Is any documentation available for the CLI backup command?
How can I tell progress? Or that it’s working at all?
Hi @aodocs-storage,
Here are a couple of relvant posts on the CLI backup feature:
As said above, its an early beta of backup functionality, so its pretty bare-bones. There is a log for backup in ~/.odrive-agent/log/backup.log and the status CLI command will give some basic overview info, like if the backup is running.
On Windows, where is the backup.log? The one stored in c:\Users<username>.odrive\log is size zero.
% odrive status returns
odrive Make Cloud Storage THE WAY IT SHOULD BE.
isActivated: True hasSession: True
email: accountType: Google
syncEnabled: False version: prod 6252
placeholderThreshold: neverDownload autoUnsyncThreshold: day
downloadThrottlingThreshold: unlimited uploadThrottlingThreshold: normal
autoTrashThreshold: never Mounts: 2
xlThreshold: never Backups: 2Sync Requests: 0
Background Requests: 0
Uploads: 0
Trash: 0
Waiting: 0
Not Allowed: 0
How can I tell what those 2 backup jobs are, and can I stop/cancel them?
Hi @a_user_of_this_tool,
You can get the backup info with the status --backup command. You can remove backups using the removebackup command.
