When the ODrive explorer extensions are enabled on Windows 10 Explorer folders that you pin so you can access them from the task bar no longer work. They still show up but only the main “File Explorer” opens a new window.
This is with Windows 10 64 bit with latest odrive 5354 but has been a problem for several versions at least.
Hand editing the registry to turn off the two File Explorer extensions returns the pinned folder explorer to it’s properly working state.
Not an acceptable work around, however, since that removes the sync/unsync icons.
