oDrive blue and pink icon behaviour?
Hi
I’ve recently started using oDrive to sync folders containing images to Amazon Drive. As far as I can tell everything synchronised OK but I’ve noticed that some of the Blue Tick icons occasionally change temporarily to Pink Synchronising icons and back again even though no files have changed.
It is as though oDrive is scanning the folders looking for changes and the icons change temporarily whilst this is happening.
Has anyone else noticed this behaviour, is it to be expected?
Thank for your help
Hi @irwmain,
You are correct. odrive will occasionally scan things to make sure no changes on either side have taken place or been missed. During this process you can see the icons change. A larger scale and layout of your odrive structure and make it more noticeable, but it is expected and nothing to be worried about.
Excellent, thank you for the prompt response.
