We released new versions of the odrive agent and CLI across all platforms earlier this month.
The agent releases brought the sync engine in-line with our desktop releases and added Encryptor support.
For encryption support, there is a new command encpassphrase that will allow you to specify a passphrase for an Encryptor folder.
usage: odrive encpassphrase [-h] [--initialize] passphrase id
positional arguments:
passphrase Encryptor folder passphrase
id Encryptor ID
optional arguments:
-h, --help show this help message and exit
--initialize Initialize a new Encryptor folder passphrase. Do not use if
passphrase has already been set
To use this command you need to specify the passphrase and the Encryptor folder ID. The Encryptor folder ID can be obtained by trying to sync an Encryptor folder before a passphrase has been specified.
You will see a message like this when trying to sync an Encryptor folder that has never been setup:
No passphrase set for 11111111-1111-1111-1111-111111111111-11111111
Set a passphrase with encpassphrase --initialize.
For example: encpassphrase --initialize [your passphrase here] 11111111-1111-1111-1111-111111111111-11111111
You will see a message like this when trying to sync an Encryptor folder that has been setup previously, but never accessed on this system:
No passphrase stored for 11111111-1111-1111-1111-111111111111-11111111
Specify your passphrase with encpassphrase.
For example: encpassphrase [your passphrase here] 11111111-1111-1111-1111-111111111111-11111111
