I’m getting the following error when trying to sync my files.
Check Network or proxy settingsMy network works great and I don’t see any added proxy settings. Can you please help?
Are you seeing this error with all files and folders you are trying to sync, or just this one?
Can you send a diagnostic from the odrive tray menu?
Hi @greysonb
The diagnostic didn’t seem to make it, which indicates a real network issue. Can you try restarting odrive to see if the behavior persists? If it does, can you try restarting your system please?
It seems to be working right now. I’ll get back to you if it stops.
Thank you!!
Was this after a restart?
yes. I did a full system restart.
