Somehow one of my previously sync’d folder was completely deleted.
https://gyazo.com/ba42bad49331bbf5017ac539ad3753b0
I went back into odrive and amazon drive to make sure /WM did not exist. When I go back to sync the folder on my Mac using odrive, I always get the prompt in the screenshot above.
Please tell me how I can reset this, thanks!
Hi @kai.sounthala, This sounds related to your other ticket, but you may have figured out the “sync to odrive” piece after submitting that one … ?
I can’t quite tell what is going on here, but what happens if you rename WM to something else? Does it allow you to sync it again?
Can you send a diagnostic from the odrive tray menu?
