I currently have O-Drive set up on a second SSD in my machine, to keep my personal google account separate from my work one. I also often have larger files in my work google account, and so like to partition my local storage in this way.
My place of work has started using Team Drive, and this all seems to be working ok via the odrive folder on my MacintoshHD.
I would like to be able to sync the new Team Drives folder (and only the Team Drives folder) to my second SSD where my other work google account syncs.
Hi @giles,
“sync to odrive” will merge the content of the local and remote folders that were chosen for sync. If the local folder is empty, then you will just see the remote files listed (as placeholders, initially).
Hi @tony - all seems to be working now. For future reference, does the folder created locally need to have a name that exactly matches the one in the cloud?
